steele32701
Sep 14, 2022Aspirant
I updated router before satellites and now can't manually update sats
I have exactly the same problem. Did anyone get a suggestion?
Sep 14, 2022Guru - Experienced User
Downgrade the CBR back to prior working version. Then update the RBS.
Be sure your updating CBR and RBS FW what come with the CBR from this linked site:
https://www.netgear.com/support/product/cbk752.aspx#download
DO NOT USE FW versions from the RBK7 series system for your RBS. Will NOT work!
