ichisdeno
Mar 20, 2023Follower
I want to assign static IPs to my devices to see if that helps me lose my internet connection less
I want to assign static IPs to my devices to see if that helps me lose my internet connection less often (RBR50 and RBS50). I know that I can reserve IP addresses in Advanced / Setup / LAN, and that ...
defjaf
Mar 20, 2023Tutor
Is there possibly some confusion between a static IP address set on the "client" device, and a reserved IP address set on the router?
KevinLiT
Mar 22, 2023NETGEAR Moderator
Hello Defjaf,
Welcome to the NETGEAR Community!
I understand that you would like clarification on the reserved IP addresses in your Orbi RBR50 router and the static IP addresses on the client-side devices.
The reserved IP address in the router ensures that those IP addresses are not automatically assigned. This allows the user to manually (static) assign IP addresses to client-side devices. This allows the user to pick a reserved IP address from the reserved list for a specific end-user device.
Below are the steps to manually (static) assign an IP address to a client from the router:
- In the Address Reservation section, click or tap the Add button.
- In the IP Address field, type in the IP address to assign to the computer or server.
Choose an IP address from the router’s LAN subnet, such as 192.168.1.x. - Type the MAC address of the client-side device to be assigned an IP address.
Best,
Kevin
Community Team
