Legendary
Dec 17, 2017Star
I wish I could return this pile of junk
I’ve owned an Orbi since May, I believe. The first few months were amazing! It worked so well and I had no problems with it. The platform was super stable and I never had to reset either the Router...
st_shaw
Dec 17, 2017Master
I would try to move the satellite and/or router to different positions so they have fewer walls between or are closer together. Recent firmware (released a few months after your purchase) reduced the effective satellite to router range for a stable backhaul. If your backhaul signal is not strong enough, you will have intermittent issues like you describe.
