finny23j
Jan 25, 2019Aspirant
I would like to force the Remote Management address to be the address of my Xfinity Cable modem addr
I would like to port forward my remote management feature on my cable modem. I currently it is set to 10.0.0.x which is on the cable modem network. I would like to set it so it has the public ip of t...
Jan 25, 2019Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? If so...
ouple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
- finny23jJan 25, 2019Aspirant
Great, I will try those options and see if I can get it working.
Thanks for the help
