RickF818
Jun 18, 2020Aspirant
iAqualink 2.0 Issues
I have an Orbi RBR50 and two RBS50's and and outdoor Orbi too. All work great. However, one device, my iAqualink 2.0 cannot maintain a connection to the network. The manufacturer of that product s...
- Jun 18, 2020
A hardwired connection would probably be the best.
Jun 18, 2020Guru - Experienced User
No, the extender will connect to the host wifi signal and what ever the security mode is set on the host wifi signal. You can setup a wired AP separately then you can set a different security mode.
Same the Mfr of this device isn't supporting WPA2 fully. WPA and older modes are mostly not used anymore and have been compromised.
- plemansJun 18, 2020Guru - Experienced User
the iaqualink 2.0 has an ethernet jack doesn't it?
You could hardwire in one of the satellites to the iaqualink if one is close to it.
- RickF818Jun 18, 2020Aspirant
Interestingly, the builder of this house hardwired a WAP in the ceiling in the closest room back to the ATT modem upstairs. It has enough of a signal to give me limited connectivity to the pool using the old, pre-Orbi, network. I suppose I could either replace it with somehthing more powerful that can put a stronger signal out through the cinderblock wall or put a range extender for that signal as close to the wall as possible.
