Sweepr9
Jun 06, 2020Aspirant
iAquaLink and rbr40
I have had an orbi Rbr40 with multiple satellites for almost 2 years with no issues. I have an iAquaLink iq900 that has been wired directly into one of the satellites to connect. There have not been a...
tucsontico
Jun 07, 2020Virtuoso
A little more information is needed to try to help you:
1) Which firmware is loaded?
2) Are the satellites and router on the same version?
3) What troubleshooting have you done so far, e.g., have you tried to power cycle the entire system and resync the satellites?
Ultimately, solving your issue may requre a factory reset of all of the ORBI components and a reconfiguring the system from scratch (not a backup config file).
Good Luck!
