BobDuke's avatar
BobDuke
Apprentice
Jan 20, 2018
Identification of Orbi back haul
Using a WiFi analyzer app, I see a number of networks sharing the same channels as my Orbi.  It's easy to identify the client networks.
How do I identify the Orbi back haul network?
SSID?
MAC?
Thanks.
Bob
  • The backhaul is hidden. You can only see it with a few combinations of scanning software and WiFi adapter. Only a very few will show the signal consistently.
    • BobDuke's avatar
      BobDuke
      Apprentice
      The SSID may be hidden, but as Netgear must follow standards to use WiFi, the chanels, etc. are defined.  So I did some more digging with my handy dandy WiFi Analyser, and found a note from a fellow Orbi user that clarified the use of a 2.4 GHz channel as part of the backhaul.
      These are the Mac addresses and Channels used between the Orbi and clients.
      Router  Mac 08:02:8e:a6:d3:66  Ch 48
      Sat       Mac 08:02:8e:a7:86:80  Ch 48
      Router  Mac 0e:02:8e:a6:d3:64  Ch 3+7
      Sat       Mac 0e:02:8e:a7:86:7e  Ch 3+7
      Then I found these "hidden" SSID's, which are probably for the backhaul:
      Router  Mac 08:02:8e:a6:d3:67  Ch 157
      Sat       Mac 08:02:8e:a7:86:81  Ch 157
      Router  Mac 12:02:8e:a6:d3:64  Ch 3+7
      Sat       Mac 12:02:8e:a7:86:7e  Ch 3+7
      There may be other "hidden" SSID's.  And i might have missed a few things.
      It's interresting, in a good way, how the first and last portion of Mac addresses are manipulated based on usage.
      I think a lot uf us like to understand how our systems ("toys") actually function.  The more we know, the better we can be at providing accurate feedback to Netgear.
      Bob
