Delphimon
Mar 16, 2020Follower
If you are having "dropouts" with 2.5.1.8 firmware please read
I recently upgraded to firmware 2.5.1.8 to attempt to fix another problem I was having, but ever since I've noticed that the router seems to lose it's connection multiple times per day. As one other ...
Mar 16, 2020Guru - Experienced User
Factory reset after a FW update or problems seen after a FW update should be done as well. I haven't seen this issue. Others as well. Not everyone has the same ISP configurations.
Retired_Member
Mar 16, 2020
FURRYe38 wrote:Factory reset after a FW update or problems seen after a FW update should be done as well. I haven't seen this issue. Others as well. Not everyone has the same ISP configurations.
factory reset should not be required. lost passwords yes.
