Delphimon
Mar 16, 2020Follower
If you are having "dropouts" with 2.5.1.8 firmware please read
I recently upgraded to firmware 2.5.1.8 to attempt to fix another problem I was having, but ever since I've noticed that the router seems to lose it's connection multiple times per day. As one other ...
SW_
Mar 16, 2020Prodigy
Delphimon, This might not be specific to v2.5.18. I had similar issues in the past with various firmware versions. The solution that works best for my Orib setup is to put Orbi in AP mode, assign Orbi/Satellite reserved/static IP addresses, DNS servers, and let the ISP Modem Router or your private router handlles DHCP/DNS/Routing chores. Orbi's strength is WiFi coverage and its backhaul. If you have some spare cycles, give it a try. Here is an example of my config.
FWIW, v2.5.1.8 has been the most stable firmware released with the best performance to date for my setup. YMMV.
Retired_Member
Mar 16, 2020
SW_ wrote:Delphimon, This might not be specific to v2.5.18. I had similar issues in the past with various firmware versions. The solution that works best for my Orib setup is to put Orbi in AP mode, assign Orbi/Satellite reserved/static IP addresses, DNS servers, and let the ISP Modem Router or your private router handlles DHCP/DNS/Routing chores. Orbi's strength is WiFi coverage and its backhaul. If you have some spare cycles, give it a try. Here is an example of my config.
wow...perhaps a bit heavy for the 'average' user. :smileyindifferent:
I'm glad v2.5.18 works for you. Like some have mentioned here, there are many ISP/system configuations out there.
What improvements did you see with v2.5.18?
