Delphimon
Mar 16, 2020Follower
If you are having "dropouts" with 2.5.1.8 firmware please read
I recently upgraded to firmware 2.5.1.8 to attempt to fix another problem I was having, but ever since I've noticed that the router seems to lose it's connection multiple times per day. As one other ...
Mar 17, 2020Guru - Experienced User
Factory reset your RBS and RBR and setup from scratch to see if this fixes your problem before downgrading.
spatzy13 wrote:Hi
New here, i believe i must have the same issue, system which was pretty solid (3 months) prior to f/w upgrade is now flaky as hell. Satellites (x2 keep dropping out). My question is a simple one, how do I downgrade to the previous version, can’t seem to find the option anywhere
Thanks
G
spatzy13
Mar 18, 2020Aspirant
Ok will do thanks
