daDozer
May 25, 2020Tutor
If you're having issues with your ORBI, RETURN IT WHILE YOU CAN
Trust me, return it. Scanning this forum for solutions won't help. Save your time and money and return it now. You can read posts I've been involved in, and I'm done with the orbi system. Thanks for ...
daDozer
May 25, 2020Tutor
I did contact support as you suggested, with no success. I was told the same, downgrade firmware, fresh setup. I've tried about 20 different firmwares with no success. Once I told support this, seems there's no other solution. I've exhausted everything you guys have suggested, so yes you can say that I am unhappy, I will be getting a new system but I will also try to save anyone else the time and heartache this product has caused myself, and my family. With everything that needs a reliable connection nowadays such as security cameras, doorbells, etc. it is unacceptable for Netgear to treat their customers this way.
May 25, 2020Guru - Experienced User
Did you ask about an RMA?
Again not everyone has the same problems as you do. Sometimes problems are hardware related and can't be solved by FW upgrades or downgrades. So this is something that needs to be addressed by NG and RMA.
Just because you had a bad experience doesn't mean everyone does.
Hope you find something that works for you.
Good Luck.
