jwaters
Dec 03, 2020Follower
I'm encountering difficulty routing my Verizon Jetpack through my Orbi.
This previously worked with my Verizon Smarthub. I live in a rural area and am looking for an internet solution that works with my Orbi. Any suggestions?
Dec 04, 2020Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
jwaters wrote:This previously worked with my Verizon Smarthub. I live in a rural area and am looking for an internet solution that works with my Orbi. Any suggestions?
