tdcarp
Aug 25, 2021Aspirant
I'm I correct that the RBK50 does not include a modem?
I going to replace a Netgear ORBI CBR40 with a couple Netgear EX6100 extenders. Although mesh is probably overkill for us, I looked at the RBK50 mesh router/extender. The CBR40 was a modem/router. ...
Aug 25, 2021Guru - Experienced User
Is the CBR40 not working for you?
Any RBR or RBK model does NOT have a built in modem and relies on connecting to a ISP service modem/ONT or other ethernet connection providing internet services.
The CBR40 can work as a modem only.
The CBR40 can still be used as a modem only or in router mode and add a RBS20 or RBS40v to it for additional coverage for better coverage and freature operation.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected
RBK50 and RBR50 are the same series. RB(K) is the kit version which has a RB(R)50 router and and RB(S)50 satellite in the box.
