Orbi_hell
Mar 22, 2018Aspirant
I'm in Orbi hell
I know I should probably just sit quietly on the sidelines and read all the other tales of woe, and add a ++metoo to the thread. But I'm honestly staggered by how badly I'm let down. I bought a ...
Mar 22, 2018Guru - Experienced User
Ok, well, for AP mode configuration, yes, use LAN to LAN AP mode on the R8000 connected to the Orbi router. Just set the Orbi routers wifi channes to manual 11 on 2.4Ghz and 36 or 48 on 5Ghz, then set the R8000 to channel 1 on 2.Ghz and 149 on 5Ghz.
You can try using same SSID and PW for both Orbi and R8000. You might seen some roaming issues. Something you would have to test out. If you see some odd behavior, change the SSID on the R8000 to something else on both radios and try again.
mcgunnerthegru1
Thanks. I will give your suggestions a try and see what happens. Will update you on results. Again thanks.
- FURRYe38Mar 22, 2018Guru - Experienced User
Good Luck.
