TimWA
Jan 06, 2023Aspirant
I'm using an Orbi RBR20 with 3 RBS20 satellites
Running into the same problem. I'm using an Orbi RBR20 with 3 RBS20 satellites, all running v2.7.4.24.
Things worked fine for years, and just started having problems within the last couple of m...
GatorJerryH
Feb 07, 2023Aspirant
Were you able to get this resolved? If so what did you do? I am having the same issue. I have an RB50 as my main router with one RB50 satellite and two RB 20 satellites.
I have tried turning off Daisy Chain Technology and setting 2.4Ghz on channel 01 (per another post) and neither one of these worked.
- TimWAFeb 07, 2023Aspirant
For us, it seems to be some kind of interaction with the Parental Controls stuff. I moved all the Amazon hardware to "unmanaged" in the Circle app and things seem to be working ok now. They were previously in the Home profile with no restrictions (the default).
