scubadreamer
Aug 18, 2020Aspirant
IMac not able to access Internet
I have enbled Circle and use it to manage my devices with no issue. Until last week, my iMac not able to connect to internet from 5+pm onwards. All other machines no issue. I ahve checked all set...
scubadreamer
Aug 19, 2020Aspirant
Tried your suggestion but iMac still not able to connect to internet.
Mstrbig
Aug 19, 2020Master
Is mit still not allowing access at the same time? If so it is software or switch based.
- scubadreamerAug 19, 2020Aspirant
I've connect to another wifi hotspot and Internet works immediately for the machine.
Hence, it is relating to Orbi or Circle. Could not find any settings in the Orbi admin page to limit time access for client.
- MstrbigAug 19, 2020Master
scubadreamer wrote:I've connect to another wifi hotspot and Internet works immediately for the machine.
When you say hotspot, you are saying it will connect through you same internet access, meaning the internet your Orbi is connected to?
I use a 4G Hotspot which provide a different Internet access path.
Orbi is connected to fibre broadband service.
Once connected to the 4G Hotspot, my iMac internet connection resume.
