jmielke
Oct 17, 2018Aspirant
iMac won't join network
imac running mojave immediately says it can't join the network when the SSID is selected. Sometimes it asks for the password and then says it can't join the network. The machine can join other networ...
ekhalil
Oct 18, 2018Master
jmielke wrote:
imac running mojave immediately says it can't join the network when the SSID is selected. Sometimes it asks for the password and then says it can't join the network. The machine can join other networks; just not the Orbi.
In my case such "starnge" issues -I noticed- were not directly related to the device or Orbi but were caused by "loops" in my network!
Please disconnect all wired devices, restart Orbi and see if the issue will be gone. If yes, then start connecting the devices one by one to locate which device is causing the issue. If you have ethernet mesh speaker (Sonos for example) then most probably it's them causing all your troubles.
