Mikeal1st
May 11, 2020Follower
Images in email web
Certain images in email and the web sites linked to them don't load, but if I use my cable router they come through fine. This appeared to start happening two weeks ago for some unknown reason. I al...
May 12, 2020Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Built in router here? IF so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Mikeal1st wrote:Certain images in email and the web sites linked to them don't load, but if I use my cable router they come through fine. This appeared to start happening two weeks ago for some unknown reason. I also have some devices in the house that are showing an error in the connection to Or I but I'm not sure what they mean. I have since restarted all networks in my house and reset the Orbi system to factory setting but the problem continues. I have an Orbi RBR 50 with one satellite connected by Ethernet.
