Atlixnor
Jan 13, 2020Guide
Immense troubles to get Sonos working on Orbi RBK50 3 node system
When I started this journey I just used my cable-modem router and Sonos worked great. Since then my network has got more and more populated and advanced. I am running 2 Zigbee networks at Zigbee chan...
clammerds
Jan 13, 2020Apprentice
I have a similar setup - Orbi RBR50, SmartThings, Hue and Sonos and all works fine with each other.
What firmware are you running? I am running the 2.5.1.8 firmware. Not sure what other hints I can give you.
My 2.4Ghz channel is set to 1, 5Ghz set to 36.
In advanced wireless options, I have implicit beam forming on, MU-MIMO on and Fast Roaming off. Daisy chain topology is off.
All my Sonos speakers have static ip addresses assigned as does my Satellite.
Hope some of that info is helpful and you get it all working!
- AtlixnorJan 13, 2020Guide
clammerds wrote:I have a similar setup - Orbi RBR50, SmartThings, Hue and Sonos and all works fine with each other.
My 2.4Ghz channel is set to 1, 5Ghz set to 36.In advanced wireless options, I have implicit beam forming on, MU-MIMO on and Fast Roaming off. Daisy chain topology is off.
Thanks. I have the same. Is your ST hub next to any of the Orbi nodes? Do you have neighbors around with strong wifi signals? I will try tweaking the advanced settings. I just tried the Auto-setting, which set my channel to 13, which did not even start Sonos. My six Sonos Speakers are not static, not sue why you did that. What is your Sonos health? Network matrix. If you don´t know how to get it, I can show you.
- clammerdsJan 13, 2020Apprentice
My ST hub is on a shelf underneath the orbi router so yes, very close.
I have made them static as with a previous firmware at least, it seemed to make it all stable. When I say they're static, I don't mean I've made the speakers themselves static but my DHCP server assigns them the same IP address every time they request one. You can do that in the LAN Setup section in the advanced tab of the router.For info, I have 7 Sonos speakers all in all.
Don't know about how to get Sonos health. If you tell me how, I'll happily look for you.
I am exited to test Sonos now after doing the changes in Advanced. I am attaching my other settings, too., which also is default. Maybe there are more differences?
To check Sonos health: http://10.0.0.21:1400/support/review
