Atlixnor
Jan 13, 2020Guide
Immense troubles to get Sonos working on Orbi RBK50 3 node system
When I started this journey I just used my cable-modem router and Sonos worked great. Since then my network has got more and more populated and advanced. I am running 2 Zigbee networks at Zigbee chan...
CrimpOn
Jan 13, 2020Guru - Experienced User
It's pretty clear that Zigbee is not likely to be causing any problems with your WiFi on channel 1. https://acuitysupport.zendesk.com/hc/en-us/articles/225413967-Zigbee-Networking-Basics-35-000ft-view-
Sonos makes so many products. It might help to describe which Sonos is having a problem.
Atlixnor
Jan 13, 2020Guide
Not so sure, I am pretty sure it worked when I turned off the Smartthingshub. Maybe the people getting it to work have more networks points than me? I have to place the ST hub right besides the Orbi Satellite or router.
CrimpOn wrote:It's pretty clear that Zigbee is not likely to be causing any problems with your WiFi on channel 1. https://acuitysupport.zendesk.com/hc/en-us/articles/225413967-Zigbee-Networking-Basics-35-000ft-view-
