Atlixnor
Jan 13, 2020Guide
Immense troubles to get Sonos working on Orbi RBK50 3 node system
When I started this journey I just used my cable-modem router and Sonos worked great. Since then my network has got more and more populated and advanced. I am running 2 Zigbee networks at Zigbee chan...
clammerds
Jan 13, 2020Apprentice
My ST hub is on a shelf underneath the orbi router so yes, very close.
I have made them static as with a previous firmware at least, it seemed to make it all stable. When I say they're static, I don't mean I've made the speakers themselves static but my DHCP server assigns them the same IP address every time they request one. You can do that in the LAN Setup section in the advanced tab of the router.
For info, I have 7 Sonos speakers all in all.
Don't know about how to get Sonos health. If you tell me how, I'll happily look for you.
Atlixnor
Jan 13, 2020Guide
I am exited to test Sonos now after doing the changes in Advanced. I am attaching my other settings, too., which also is default. Maybe there are more differences?
To check Sonos health: http://10.0.0.21:1400/support/review
- AtlixnorJan 13, 2020Guide
Unfortunately still cutting off Sonos after just 2-3 minutes play. Anyone thinks I have better luck using the Nighthawk? Are there reasons that Sonos will work better there? Time is of importance as the 50 day return period for the Orbi is quickly approaching also. Will do a reboot of the Satellites also, as I did not do that. I only rebooted the Sonos devices.
Not sure yet if maybe this problem has something to do with my Sonos Play 5 speakers. One is reporting as "Zoneplayer" and the other is reporting as "Play 5". They have been set up as a Stereo pair. Will ask Sonos about this tomorrow and continue troubleshooting and hopefully we have isolated the problem to these 2 speakers.
- plemansJan 13, 2020Guru - Experienced User
I read in 1 post that having more than 1 sonos hardwired into your system with orbi can create issues. Do you have more than 1 hardwired in?
