Atlixnor
Jan 13, 2020Guide
Immense troubles to get Sonos working on Orbi RBK50 3 node system
When I started this journey I just used my cable-modem router and Sonos worked great. Since then my network has got more and more populated and advanced. I am running 2 Zigbee networks at Zigbee chan...
eljarviso
Jan 14, 2020Luminary
I have a similar setup to you (same ST hub and hue hub) and also had issues with Sonos however I fixed them all by purchasing a Sonos bridge device and having all Sonos speakers run on their own proprietary mesh system. Since I e done this everything works awesome.
Atlixnor
Jan 14, 2020Guide
Yes, this is also a solution. I found a similar solution actually. Connect one of the speakers to a LAN and it does the same: forming its own mesh-network.
I actually had the bridge and also bought the Boost. Then I read an article than in general the use of a bridge should only be used if there were few wifi networks around, otherwise it would be interference. So I sold my brand new Boost with a loss and bought the Google Wifi, and here I am, back to start, but one experience richer: Don´t assume things will work straight away and don´t sell too early :-)
