rkrippner
Oct 07, 2020Aspirant
Improving coverage
My experience with my Orbi system has been an absolute nightmare. Wifi is always dropping, my satellite continues to drop connection even though it is 40 feet from the router. Our 3,330 square foot...
Oct 07, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
- rkrippnerOct 07, 2020Aspirant
What Firmware version is currently loaded? 2.5.2.4
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Arris TM1602A
Is the Orbi system operating in Router or AP mode? RouterWhat is the size of your home? Sq Ft? 3,600 (Single level, long home)
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. It is currently about 40 feet. Sould I go longer apart?What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. After I did a factory reset, I noticed it is on Auto for 2.4, I just switched to 06, 5ghz is set to 48.
Any Wifi Neighbors near by? If so, how many? I usually do pick up 2 or 3 neighbors but right now I only see 1 (Myspectrumwifi71-2G) besides mine.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings. Done-they were not checked, so now they are.
Armor (done), Circle, Daisy Chain (done), Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only (i do not see this option, so I just disabled 20/40 coexistence). Set Short preamble instead of Long preamble modes (done). Save settings and reboot the router and satellite(s).One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...- FURRYe38Oct 07, 2020Guru - Experienced User
Lets see if the changes you made helped any.
You can go farther out at a distance between the RBR and RBS and see if this help with a bit more coverage.- rkrippnerOct 07, 2020Aspirant
Thank you SO MUCH for your time and attention. As you can imagine, this is a big deal for my family and all eyes are on me to get this figured out or install a new router.
Ron
