michel1918
Jan 10, 2019Tutor
In doubt between RKB23 and RKB50
Hi,
I am in doubt between the orbi RKB23 and the RKB50.
I have a house with3 floors, 60m2 each. Ceilings are concrete.
I understand the RKB50 is faster, but only has 1 sattelite and the RKB...
ekhalil
Jan 10, 2019Master
Please base your decision on the following facts:
1. Bandwidth:
RBK50 (AC3000) is not faster, but it supports up to 1.7Gbps backhul between the router and satellites. You need this if you have need for simultaneous high bandwidth streaming in multiple devices at the same time.
The RBK23 (AC2200) supports 867 Mbps which is not bad at all. So depending on your internet speed and how much communication you have between your devices you should be able to choose between the two. Please note that Google wifi is AC1200 and it's enogh for home use!!
2. Coverage:
The RBK50 units are physically bigger and have longer antenns so these have wider coverage than the RBK23 which are smaller. According to specs the RBK23 (1 router + 2 satellites) covers 6000 sq ft while the RBK50 (1 router + 1 satellite) covers 5000 sq ft.
On the other hand barriers and building material affects negatively the coverage c/s of the base station so if you have 3 floors you might choose to go for 1 base startion for each floor to maximize the coverage, but you also need to also think about the distance between the router and the satellites which should be around 30 ft for best wireless backhaul stability. If you will use cables for the backhaul then you can forget about this last limitation.
3. LAN ports
The RBK50 has 3 LAN ports on the router and 4 on the satellite, while the RBK23 has only one LAN port on the router and two on the satellites.
- michel1918Jan 31, 2019Tutor
Ok, thanks for the answers, decided to go for the RKB50.
- ekhalilJan 31, 2019MasterGood choice, good luck!
