Johnnyk5679
Jan 08, 2017Guide
Inconsistency with Orbi Speed
Hi I've recently bought the twin Orbi router system and I have mixed feelings about it. I have seen the fastest speed I've ever experienced using it purely by speed testing it on my iPhone 7 i.e. 3...
Johnnyk5679
Jan 08, 2017Guide
Looks like we have both extremes here , I have quite a lot of devices connected and you guys perhaps don't have nearly as many but we are all seeing a similar result. There was a new firmware update yesterday that I did but that zero effect on speeds. Prior to purchasing the Orbi router I've generally used the basic ISP provided routers apart from buying a used Apple Time Capsule for €80 which was not as fast but was more consistent, I have spent 6 times the cost of that but I am not seeing anything you could class as steady, consistent speeds - hope someone from Netgear chimes in with a fix or hope of fix soon !
Johnnyk5679
Jan 08, 2017Guide
- DarrenMJan 09, 2017Sr. NETGEAR Moderator
Hello Johnnyk5679
Does this happen on wired devices? or is it just over the wireless? Have you checked to modem itself see if you see this change in speeds?
DarrenM
- Johnnyk5679Jan 09, 2017Guide
Here's tonight's Speedtest - please look at the time intervals and the speeds I got , what causes this sporadic behavior ???
