juniormint88
Jan 14, 2017Tutor
inconsistent WiFi Speeds
Anyone else see where back-to-back speedtests go between high (400Mbps) and low (200Mbps) speeds?
st_shaw
Jan 15, 2017Master
Yes. I saw that behavior. It was because I had a WiFi scanner program open on the laptop I was using to do the speed testing. Check and make sure you don't have any other programs open that are using your WiFi interface.
- peteytestingJan 15, 2017Hero
you also have to make sure when the client switches its not going to 2.4 gig as this was catching me out during some testing until i switched off 2.4 gig on my client device so it had to connect to 5 gig only
- michael814Jan 15, 2017Star
I made sure that the Airport Utility (which is the only way to scan WiFi networks on a non-jailbroken iOS device) was not running at the time. I also ensured during testing that I was indeed connected to the 5ghz band (confirmed via the MAC address). However, I have some additional info, which I posted in this thread:
https://community.netgear.com/t5/Orbi/Inconsistency-with-Orbi-Speed/m-p/1209602#M3121
