bsholbrook
Dec 15, 2016Apprentice
Inconsistent/Inaccurate Satelite Connection Details
I have uncovered what appears to be an inconsistency in client and satelite conneciton information or a bug. Sharing screen grabs to describe the issue: The routers shows these clients are sate...
swrtwdrv
Dec 22, 2016Apprentice
I have experienced similar inconsistencies and called them invisible devices. Note that Pams-Iphone shows up on the router connected device list and not on the satellite connected device list. When this happens to me, the 5GHz portion of the satellite status screen doesn't show even though there are devices connected.
As for HunterHKSiPhone is suspect it may be connected to the router. Try the following in the router attached devices list: click on any device name to enter the edit device screen, click in the device name box, and press <enter> instead of clicking on the apply button. For me this brings up an alternate listing that shows devices attached to the router and each satellete.
I would sure like to explore how your device list shows the band while mine only shows orbi, wired or wireless. My router and satellites are all firmware V1.4.0.18.
