taohat
Feb 08, 2019Star
incorrect display of wireless vs ethernet backhaul in orbi app
I have an RBK53 system with 2 satellites, one (in basement) connected to the base via wireless backhaul and the other (in study) connected to the base via ethernet backhaul. However, orbi app (ios, l...
- Mar 15, 2019
After updating to ios app version 2.3.0.31, problem was solved. ethernet backhaul showed as solid line and wireless backhaul showed as dotted line.
CrimpOn
Feb 08, 2019Guru - Experienced User
How does the web interface show the satellites connected on the "Attached Devices" page?
- taohatFeb 08, 2019Star
The web interface shows correct connections: "wired" for the RBS50 in study and "5G" for the RBS50 in basement.
- ekhalilFeb 08, 2019Master
- Please make sure that Daisy Chain is disabled. The current software seems to have issues when you combine wired with wireless backhaul and Daisy Chain is enabled.
- It will be good to see what Orbi sends to the app to find out if it's Orbi that sends the wrong information or the app is the one wrongly interpreting the information. Please do the following:
- Close the Orbi app in your phone
- Go to the orbilogin.com/debug.htm page and enable "Save SOAP log between APP and Router".
- Click on "Start Capture"
- Open the app on your phone and click to open the network map
- Go back to the debug.htm page and click on "Save Debug Log"
- Save the zip file and open it.
- The following 2 files contain log of events interchanged between Orbi and the app:
- Open the files and search for wired and you should also see the satellite name.
- taohatMar 15, 2019Star
