AKLGUY
Jun 16, 2018Apprentice
Increasing DHCP lease time
I have only had my Orbi RBK50 for just over a week now.
Once I had the ethernet backhaul sorted (The trouble was there was a switch between the Orbi Router and Satelitte with other devices on too. I moved the LAN so it was between the two Orbi units and have the in one of the other LAN on the Satelitte, Now running smooth for 3 days and no further issues.
But what I would like to do now is, Increase the DHCP lease time, The Orbi logs are just bombarded with DCHP notifications.
I can not see anything in the settings yet for this. But it looks like the setting is 1 hour at the moment.
- AKLGUYApprentice
Correction Lease time is 24 hours. It just seems that is iphones that are continuelly getting DHCP address.
Set your devices up for IP address reservations.
I would change the default IP address pool from 192.168.1.2 thru .254 to 192.168.100 thru .200.
- AKLGUYApprentice
I already have the pool from 10.0.0.2-10.0.0.254 to 10.0.0.20-254 leaving the 10.0.0.2-10.0.0.19 for Internal servers/Printers/security cameras guess a smaller pool wont hurt
The pool should be as big as you need and just a bit over to allow for growth. 100 IPs is good enough for most homes.
- RocketSquirrelLuminary
I have also found iOS devices, and a few others, to be obnoxious in their constant DHCP requests. My solution was to give *every* device on my network a static address, or a reserved address if static wasn’t possible. (E.g., my HP OfficeJet printer forgets its static address after a power outage.) No guesswork, few DHCP requests, I know every device’s address, and my LAN runs great. “Set and forget” is my recommendation.
- AKLGUYApprentice
Thank you RocketSquirrel
I think I might move my DCHP pool up to x.x.x.100 and then move my Apple iOS/ATV devices to static IPs from the x.x.x.2x range.
Thats were I have some of my devices, ATV, printers, NAS and such. I reserve IPs for iphones and all my other devices that need some form of router management and internet access.
I see no reason to use DHCP unless a particular device requires it. DHCP is for guests on my guest network and my few devices which don’t support static addresses. It’s an extra level of unneeded complexity and only adds another point of failure.
