SdeGat
Dec 11, 2020Apprentice
Infamous RBR/RBS50 Firmware Upgrade issue
I have one of those RBR/RBS 50 setup which was stuck on firmware version 1.4 something. I followed the advice from this forum as follows: Manual update of Satellite and then Router in this order...
- Dec 12, 2020
Hopefully TFTP method will force something on the RBR> :smileytongue:
vajim
Dec 11, 2020Master
When you logged into your router via a web browser you should have been told an update is available. If not don't worry about it. Does your network work?
- SdeGatDec 11, 2020Apprentice
vajim wrote:When you logged into your router via a web browser you should have been told an update is available. If not don't worry about it. Does your network work?
My router never reported that an update was available and would still be on version 1.4 if I had relied on that. :smileysad:
- vajimDec 11, 2020Master
SdeGat wrote:My router never reported that an update was available and would still be on version 1.4 if I had relied on that. :smileysad:
OK...maybe not a bad thing IF your network works. 1.4 is extreme...most in here understand my position about FW. But it's my opinion, others will do what they choose for it's their network. I've played the FW roulette for more years than I care to count with various software, hardware, (for some reason browser comes to mind) dating back to WIN 3.0 Most of the chasing resulted in unnecessary grief.
Enjoy you update.:smileyhappy:
