benelgiac
Apr 05, 2018Initiate
Info to buy additional satellite for RBK20
Hi all I bought an RBK20, and Iḿ very satisfied. However, I'd like to buy an additional satellite to extend coverage on the lower floor. What model should I choose? I haven't found any spare sat...
- Apr 12, 2018
Ok I have asked support and they say that there is no additional satellite for that system in commerce yet... BUT, RBS40 coming from previous generation is compatible.
Now, I don't know whether to return the kit and buy the RBK23 ( which has 2 satellites ) or get the RBS40. I'll see.
Just be aware these are the only options available now. Cheers
Giacomo
Apr 05, 2018Guru - Experienced User
Is there an RBS20 avialable?
Something to ask NG support about and see. I believe this model should be a good match...
benelgiac
Apr 12, 2018Initiate
Giacomo
- FURRYe38Apr 12, 2018Guru - Experienced User
Thanks for letting us know.
Good Luck.
