Dec 11, 2019Follower
Initial setup RBK13 router on smartphone
orbi setup is saying it is unsecured which I believe is not allowing me to setup the router
Dec 11, 2019Guru - Experienced User
Use a wired PC to setup the system. Be sure you change the SSID name to something custom and input a password for the wireless and give a PW for the admin log in. Use any broswer.
5089 wrote:orbi setup is saying it is unsecured which I believe is not allowing me to setup the router
