piemmm
Aug 04, 2021Aspirant
Insecure WiFi on Orbi RBR850 when WPA2 enabled
Hello! Has anyone noticed that the Orbi creates an unencrypted WiFi network (as well as an encrypted one with the same name, and you only get to see the encrypted one on most phones)? My conf...
Aug 04, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
- piemmmAug 04, 2021Aspirant
Ok I'll repost on over there, thanks - though netgear should probably be alerted to this as it's a big one given it's allowing networks to be joined without a password
- FURRYe38Aug 04, 2021Guru - Experienced User
Lets trouble shoot that first. Mines not seeing this issue. :smileywink:
