piemmm
Aug 04, 2021Aspirant
Insecure WiFi on Orbi RBR850 when WPA2 enabled
Hello! Has anyone noticed that the Orbi creates an unencrypted WiFi network (as well as an encrypted one with the same name, and you only get to see the encrypted one on most phones)? My conf...
CrimpOn
Aug 04, 2021Guru - Experienced User
piemmm wrote:Has anyone noticed that the Orbi creates an unencrypted WiFi network (as well as an encrypted one with the same name, and you only get to see the encrypted one on most phones)?
Reboot - you get 2 networks on 5g, one encrypted and not encrypted on the satellites. Logged into the sattelite web interface to confirm it (and logging in passwordless on my devices as well. Shocking).
Comments netgear?
Interesting that WPA2-WPA3-MIXED does not appear in the User Manual. Is it a choice in the WiFi setup?
Does a WiFi analyzer program show both the secure and unsecure 5G WiFi Access Point radios on the router and satellites?
(I use WiFi Analyzer by Kevin Yuan on Android and WiFi Info View by nirsoft on Windows. Each AP has a unique MAC address for the 2.4G and 5G radios, so there should be three 2.4G entries and three 5G entries for SSID H-LOUNGE-5. And, they should all have a 'lock' symbol.)
- FURRYe38Aug 04, 2021Guru - Experienced User
Mixed WPA mode is not supported on Orbi AX systems. Was initially but then it was removed. Too many problems with WPA3.
- CrimpOnAug 04, 2021Guru - Experienced User
FURRYe38 wrote:Mixed WPA mode is not supported on Orbi AX systems. Was initially but then it was removed. Too many problems with WPA3.
That's why I was confused to see that on the attached image. I have never seen a WiFi system with security that will allow a device to connect with no password at all. Your AX Orbi doesn't do this, does it?
No. I even checked mine again to be sure.
A couple of others posted seeing this however a full on reset and resync of the RBS one at a time resolves this. For some odd reason the sync doesn't get fully seated on the RBS. :smileyembarrassed:
