gigberk
Jun 26, 2019Aspirant
install zipped downloads for orbi
What can I do to download and install the zipped software updates for orbi? They download but will not unzip! This is the most useless download system I've ever worked with. Help!
- Jun 27, 2019
Ok. Glad you got it working. Please mark your thread as solved so other will know. Enjoy. :smileywink:
Jun 27, 2019Guru - Experienced User
Any progress on this? :smileyindifferent:
gigberk wrote:What can I do to download and install the zipped software updates for orbi? They download but will not unzip! This is the most useless download system I've ever worked with. Help!
gigberk
Jun 27, 2019Aspirant
Furry, I finally got the app to work. I removed it and re installed it on my phone. I did a full set up and the updates were then easily installed. There must have been an issue in my original app download but now it's working fine. Thanks for your help. Gig
- FURRYe38Jun 27, 2019Guru - Experienced User
