dan_123
Aug 28, 2018Tutor
Installed Orbi and data usage quadrupled!
I purchased and installed an RBR50 AC5000 with a Satellite RBS50 on July 5. It worked great. I had much more coverage for our house/property and all our devices were able to connect from everywhere a...
mikepcdoc
Oct 03, 2018Aspirant
I also have the same issue that after installing the RBK43 system my data usage went from 250gb/month to 2.2tb/month. How do I fix this? My network is down more than it is up because of it.
- FURRYe38Oct 04, 2018Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of prior router used?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Have you enabled Traffic Meter?
