dan_123
Aug 28, 2018Tutor
Installed Orbi and data usage quadrupled!
I purchased and installed an RBR50 AC5000 with a Satellite RBS50 on July 5. It worked great. I had much more coverage for our house/property and all our devices were able to connect from everywhere a...
Zaggles
Jan 19, 2019Aspirant
Did you guys ever find a solution to this or identify the issue?
I picked up the Orbi system on Black Friday, and for the first time ever hit data caps in both December and January. The Orbi app shows consistent 20GB+ usage a day - there are only two adults living in my house, and we both work during the day. We use internet quite a bit and we stream Netflix and whatnot in the evenings, but not nearly 20GB worth a day. Really wish Orbi gave the option to see by-device usage versus overall usage so I could do some basic troubleshooting. As it is, I'm probably just going to return this system and shoot for Google if no one has identified a cause/fix.
Jan 21, 2019Guru - Experienced User
What FW is currently loaded?
Has the system been factory reset and setup from scratch by chance?
Whats connected to the system?
Is Guest Network enabled?
- josepieJan 31, 2019Tutor
I am having this exact same issue.
Anyone know of a way to check what is causing this data usage? I'm at 1.2TB in 4 weeks, up from 300GB last month. Nothing new added, current firmware etc.
- FURRYe38Jan 31, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too?Has the system been factory reset and setup from scratch by chance?
Hi Furrye38, thanks for the response. But I do not think this is a FW issue or similar.
I guess it was answered in a different thread. There is no fix for this. Netgear do not acknowledge the issue of not being able to see what is using bandwidth, which device specifically. Seems a lot of people are complaining about this issue. Some suspect its partially related to Comcast.
