EyalB
Aug 15, 2017Aspirant
Installed Orbi with AT&T Internet, worked 12 hours, then upload speeds crashed
I installed an Orbi AC3000, connected to a Pace 5268AC on AT&T Internet. I set the The Orbi to AB mode, then I bypassed the 5268AC by disabling wifi on it. Speeds were 35-40Mbps download and 4-6Mbps ...
EyalB
Aug 17, 2017Aspirant
I have not. Unless those are enabled by default, they are disabled.
DarrenM
Aug 17, 2017Sr. NETGEAR Moderator
Try that its in the advanced wireless settings.
DarrenM
- EyalBAug 18, 2017Aspirant
I enabled beamforming and mumimo, same issue. Upload is still in the 0.1 - 0.3 range consistantly.
- DarrenMAug 18, 2017Sr. NETGEAR Moderator
Hello EyalB
Can you send me a PM with your name, email, and phone number I want to get you over to support and work on this issue.
DarrenM
