nicks089
Jun 25, 2020Follower
Installing 2 different Orbi systems (RBS20 and RBK10)
Hi, I have an RBS20 Router and Satellite installed (currently in AP mode) and I want a 3rd and 4th unit to extend the coverage. There's currently a good deal on an RBK10 Router and Satellite, an...
Jun 25, 2020Guru - Experienced User
You potentially could make something work but I wouldn't. The RBK10 system is the dual band orbi and not the triband orbi. As well as you don't want 2 orbi routers running on the same network if you want your seamless roaming to function properly. Basically, forcing something to work (if you could get it) would make your system unstable, not roam properly, and the rbk10 devices would run much slower than the triband versions.
The satellites you can use?
rbs20
rbw30
rbs40
rbs40v
rbs50
rbs50y
these would all have the tri-band backhaul fo the rbk20 system and would be compatible.
