nicks089
Jun 25, 2020Follower
Installing 2 different Orbi systems (RBS20 and RBK10)
Hi, I have an RBS20 Router and Satellite installed (currently in AP mode) and I want a 3rd and 4th unit to extend the coverage. There's currently a good deal on an RBK10 Router and Satellite, an...
Jun 25, 2020Guru - Experienced User
From what others have posted, theyve tried to make the 1 series work with other Orbi systems and have failed. We can only presume the 1 series is not compatible with other Orbi systems. I would avoid mixing and trying to match up 1 series with other orbi systems.
nicks089 wrote:Hi,
I have an RBS20 Router and Satellite installed (currently in AP mode) and I want a 3rd and 4th unit to extend the coverage. There's currently a good deal on an RBK10 Router and Satellite, and I wanted to know if I could mix these systems together?
I would install the RBK10 router in AP mode where the existing RBS20 Satellite is, and then run both satellite units in satellite mode. IS this possible to run both systems (4 units) with the same SSID/network?
