DeckerBob
Aug 13, 2019Follower
Installing my Govee wireless system
I’m trying to set up my new Govee Wireless temperature humidity system in my home so I can monitor temperatures on my iPhone govee system does not work with the 5G connection how do I connect it to th...
michaelkenward
Aug 15, 2019Guru - Experienced User
DeckerBob wrote:
I’m trying to set up my new Govee Wireless temperature humidity system in my home so I can monitor temperatures on my iPhone govee system does not work with the 5G connection how do I connect it to the 2.4 G?
Have you asked the people who made the Govee system?
It is down to them to write software that allows you to connect to whatever wifi is available.
You may be able to disable the 5 GHz on your C6300 temporarily.
There is a support for the C6300, including a manual, somewhere at the end of this link:
>>>> C6300 | Product | Support | NETGEAR <<<<
By the way, but you have posted your message in the section of this community given over to Home WiFi Adapters. (This is easily done, given Netgear's impenetrable community structure.)
If you need more help, you might get better and quicker replies, and find other answers, over in the appropriate section for the C6300:
Cable Modems & Routers
- AredubJan 30, 2020Tutor
After much frustration (and no help from Govee) I was able to connect my Govee H5040 water detector to my Orbi network. The key: I still had an EX2700 range extender from before I bought the Orbi. The extender only works at 2.4ghz. So the steps were:
1) Plug in the extender2) Log my phone out of the Orbi network and into the EXT network
3) Push the blue button on the Govee gateway. (Note -- the gateway has 2 buttons and both cause a blue light to flash. I was pushing the wrong one for a while.)
4) Use the Govee app to add the Govee gateway and log into the EXT network.
Done!
If you don't have a 2.4 range extender, maybe you have an old router non-mesh router.
- michaelkenwardJan 31, 2020Guru - Experienced User
Aredub wrote:If you don't have a 2.4 range extender, maybe you have an old router non-mesh router.
Or, as suggested earlier, simply tell the Mesh system to temporarily stop broadcasting the 5 GHz SSID. That is a well known and widely discussed strategy that has worked for many different IoT devices.
Thanks for reporting back on this one. With luck anyone who turns up here with the same issue will search this place for Govee and will find your solution.
Let's hope that DeckerBob can use one of these strategies.
- AredubJan 31, 2020Tutor
Thanks, michaelkenward Netgear support wasn't helpful when I asked how to disable the 5ghz band. I found references ibn the community saying it could be done via the command line, but didn't find directions. I also couldn't find a way to use different passwords or SSIDs for each band.
