Aches
Jan 03, 2020Aspirant
Installing Orbi CBR40 and RBR20 in 2 buildings
I want to have WiFi in a garage150 feet away. In the main house I have installed CBR40 with 2 satellites and it preforms great. 150 feet away I have a 2 floor garage with a cement floor between t...
Jan 04, 2020Guru - Experienced User
Be sure to post about this in the Orbi with built in cable modem here:
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
Concrete and WiFi do not get alone. Wired will be preferred here.
Aches wrote:I want to have WiFi in a garage150 feet away.
In the main house I have installed CBR40 with 2 satellites and it preforms great. 150 feet away I have a 2 floor garage with a cement floor between the 2 floors. I have a cat 6 network cable running from Switch the Orbi CBR40 is connected to the garage. How do you recommend I configure the RBR20 and it satellite to provide WiFi to the garage? Do I use the same SSID?
