Netcando
Jul 12, 2021Follower
Integrating a Orbi Mesh with an existing Nighthawk router
Hello and thank you for your help. My Current setup is a Nighthawk AX6600 (RAX70) Triband Router and I would like to intergrate a AX4200 WiFi Mesh System (RBK753). I would like to contuue to use my...
Jul 12, 2021Guru - Experienced User
Can you use them at the same time? Yes
will they integrate? no
What I did with mine was to use the RAX as router mode and put the orbi system in access point mode.
That prevented the double nat.
Then I just used a different ssid for the RAX and made sure it was on different wireless channels from the orbi.
