ORBIssues
Jul 23, 2017Aspirant
Intermittent Connection
I use Sonos to listen to internet radio. Before I bought ORBI, I would have issues where the internet radio broadcast would frequently stop (and have to constantly be manually restarted, which was an...
cyberprashant
Jul 23, 2017Luminary
Check your orbi firmware version. Orbi was rock-solid for a lot of people until recent update to version 1.12.0.18 including me. I had to downgrade and then block the upgrade (see page 5 of the 1.12.0 .18 discussion thread)
- ORBIssuesJul 23, 2017Aspirant
Hello and thanks for the prompt response. I thought I had found the discussion thread you mentioned, but did not see anything on page five about downgrading the firmware version and then blocking the upgrade. When I type "1.12.0.18" as the search topic, multiple discussion threads come up, so perhaps I was looking at the wrong one. Would it be possible for you to post a link to the exact page you are referring to? Thanks and I appreciate your help!
- cyberprashantJul 23, 2017Luminary
https://community.netgear.com/t5/Orbi/Firmware-V1-12-0-18-Discussion/td-p/1320421/page/5
1. downgrade first (google Search for netgear RBK50 downloads - upload old firmware - go to the one previous to the current one 1.11.02.20.
2. Then follow above to prevent it from auto-upgrading again (o/w within minutes it will autoupgrade again).
