pawan2003
Mar 24, 2020Initiate
Intermittent disconnection of wifi after upgrading firmware to 2.5.1.8
Hi All! Ever since I upgraded my firmware to version 2.5.18, my wifi seems to disconnect frequently. This is particularly felt while using apple products. Also, my phone and ipad tend to connect dir...
- Retired_MemberMar 24, 2020
pawan2003 wrote:Hi All!
Ever since I upgraded my firmware to version 2.5.18, my wifi seems to disconnect frequently. This is particularly felt while using apple products. Also, my phone and ipad tend to connect directly to the router instead of the satellite located close by.
2.5.18 has issues....get rid of it
Why did you upgrade?
pawan2003
Apr 01, 2020Initiate
Thanks! I downgraded the firmware to 2.3.5.30 and the network stabilized.
Retired_Member
Apr 01, 2020
pawan2003 wrote:Thanks! I downgraded the firmware to 2.3.5.30 and the network stabilized.
Nice work.
Tip: If your system is working it's best to leave it alone. NG will auto-push any that contain critical updates.
Stay safe.
