Gellie
Jan 25, 2020Aspirant
Intermittent drops on 2.4ghz
So I noticed i'm gettign a fair amounts of drops on the 2.4ghz band on my Orbis. Not getting the drops on the Fios router. I have tried changing the channels(1,6,11) to no avail. The Orbi is in AP mo...
Jan 25, 2020Guru - Experienced User
You may want to try and lower the power out put of the Orbi radios by lowing from 100% to 75 or 50%. Under Advanced Tab/Advanced Settings/Wireless Settings
Not seen on Orbi AX.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
