Gellie
Jan 25, 2020Aspirant
Intermittent drops on 2.4ghz
So I noticed i'm gettign a fair amounts of drops on the 2.4ghz band on my Orbis. Not getting the drops on the Fios router. I have tried changing the channels(1,6,11) to no avail. The Orbi is in AP mo...
GeoffChesh
Jan 26, 2020Aspirant
Hi,
Not sure if this applies to AP mode or not (apologies), but I have been experiencing drop outs due (I think) to suspected DoS attacks. Once I disabled that protection, the WiFi signal (on all bands) held up more reliably.
If you are interested, he is the discussion link:
Hope it helps
Geoff
- FURRYe38Jan 26, 2020Guru - Experienced User
Wouldn't effect the RBR in AP mode unless the offending attacker new the IP address of the RBR while in AP mode.
GeoffChesh wrote:Hi,
Hope it helps
Geoff
- GellieJan 27, 2020Aspirant
Thanks, one new thing im trying is to turn off the wireless on my router. Just using Orbi in AP mode. Maybe the to wireless singles were interfering with each other?
- FURRYe38Jan 27, 2020Guru - Experienced User
Yes, having other wifi near by can effect or interfere with Orbi WiFi.
