XenixJr
Dec 09, 2020Aspirant
Intermittent Internet connectivity outage with Orbi RBR50
Router Firmware Version : V2.5.2.4 2.4G ChannelAuto ( 13(P) + 9(S) ) 2.4G ModeUp to 400 Mbps 5G Channel36(P)+40+44+48 5G ModeUp to 866.7 Mbps As title, things has been working fine for mon...
Dec 09, 2020Guru - Experienced User
This happen with both wired and wireless devices?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
There is more recent FW available that supersedes v4:
- XenixJrDec 11, 2020Aspirant
>> Huawei EchoLife HG8045H
>> I don't have any device connect by wire to confirm but will try to get one.What is the size of your home? Sq Ft?
>> 700sftWhat is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
>> Issue happened no matter I connect to the router or satellite. Anyway, they are less than 10 feet apart with a concrete wall between them.
>> Plenty, over 10+
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
>> Will give it a try.
>> No. Is it necessary ?
https://community.netgear.com/t5/Orbi/RBR50-RBS50-Firmware-Version-2-6-1-40/m-p/1997895/highlight/tr...
>> Let me give it a try as well.
