XenixJr
Dec 09, 2020Aspirant
Intermittent Internet connectivity outage with Orbi RBR50
Router Firmware Version : V2.5.2.4 2.4G ChannelAuto ( 13(P) + 9(S) ) 2.4G ModeUp to 400 Mbps 5G Channel36(P)+40+44+48 5G ModeUp to 866.7 Mbps As title, things has been working fine for mon...
Dec 11, 2020Guru - Experienced User
>> Huawei EchoLife HG8045H
What mode is this modem working in? This has a built in router and wifi, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
XenixJr
Dec 14, 2020Aspirant
Thanks for the help. Never heard of the Double NAT issue but great to learn something new. However, since the unit has been working ok for couple months before this happen, I am not quite sure if Double NAT is the issue. Hence, thanks sharing the "Most Stable Orbi Configurationlast" from Nibir , things seems to be stablized now. No more Internet outage after the changes. What I changed are :-
03. Fast Roaming - Disable
07. Logs - Untick logging of DoS attacks and Port scans
08. Channel 1 for 2.4 Ghz ( I changed from Auto to 1 ) and Channel 36 for Ghz ( No Change )
Will keep monitoring for couple more days and see how it goes. Thank you all :)
- alokeprasadDec 14, 2020Mentor
Curious about this recomendation.
Doesn't this depend on other WiFi signals present in the environment? Why isn't Auto or the default a good choice?
Seems rather prescriptive for everyone to select the same channels. It could be counterproductive if Orbi was very common and my neighbors follwed the same advice!
- FURRYe38Dec 14, 2020Guru - Experienced User
https://kb.netgear.com/30187/How-to-fix-issues-with-Double-NATHappens if your modem has a built in router along with using the Orbi router as well.
