Mikey94025
Sep 25, 2016Hero
Intermittent internet connectivity outage with Orbi?
I just installed my new Orbi router yesterday, replacing a Nighthawk R8500. I believe that overall wireless coverage has improved, though top-end performance is not quite as high (measured via fast....
- Sep 28, 2016
I read in the other "Ring Door Bell" thread that a customer had better results after disabling "Enable Implicit BEAMFORMING". So I tried that just to see what happens. It's probably too early to tell yet, but my 2 Nest cameras have only disconnected once in the past 2 days and I think that's because there was a power outage at my house today (I wasn't home and both cameras went out at the same time, something the intermittent outages haven't done).
faderbox
Oct 05, 2016Aspirant
My nest cam's continue to disconnect. I had to deactive the beamforming. Argh. Where's the fix, Netgear?!
- SkrymirOct 05, 2016Guide
Deactiving implicit beamforming shouldn't have any effect on newer ac devices which are supported with explicit beamforming. It sucks that we have to use a work around but it doesn't look to be that impactful to performance. But I totally agree this should have worked out of the box.
While I have been mostly happy with Orbi I intend to make to clear in my Amazon product review that Orbi does have issues.- peteytestingOct 05, 2016Hero
true but disabling implicit does effect the coverage and performance of those non ac devices that do support beamforming , disabling explicit makes no sense
Have you been able to measure the difference in implicit on/off? I wasn’t able to get any meaningful difference.
